Setting up Tivo help please
Discussion in 'Digital TV & Video Players & Recorders' started by Ian J, Dec 21, 2002.
Tags:
  1. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    Apart from being much larger than I imagined I haven't managed to set it up properly yet.
    I have one RGB input on my TV so in order to maintain RGB I have cabled Digibox - Tivo - DVD player - TV but it is definately not RGB that I am seeing. One of the problems is that the sockets on the Tivo are too close together to use fat scart leads and so I will try and buy some slimmer ones to see if I have made a bad connection. I set it to record "Have I got News for You" last night and it recorded half an hour of the cricket instead. I am sure that I will get there in the end but England seem to have changed from their traditional blue tops to green. Funny, but when I watched the game earlier, they were still wearing blue.
    My other problem is the magic eye thingy. For a start there are two magic eyes and the manual only shows one. I am also not quite clear where to put this. Should it be covering the Digibox's magic eye or should it be along side it.
    Thanks for any help and advice.
  2. thfccambs
    thfccambs
    Jul 17, 2002
    23,968
    White Hart Lane
    +6,898
  3. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,917
    71
    50 Rue St Georges, Paris.
    +32
    Assuming you have selected RGB in setting up, is this a loose scart lead maybe, try it again with normal thinner scarts.
    I have found in practice that both dongles sitting end to end below my digibox IR sensor works best for me. I ran the wire from behind my Tivo, with the dongles placed in front of the digibox, with wire hidden trailing from behind it looks neat and tidy.
    I selected front blaster off in settings too, so the only blaster is my dongle.
    It could be worth trying further codes too, maybe the initial code tried is only partially correct ?
    Tivo forums are very helpful as said already, but fire away if I can help, I have had two Tivos since they came out :) .
  4. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    I seem to have sorted some of the problems by using cheaper and thinner scart leads. I also probably hadn't found the best control codes.
    My current problem is that I don't know how to record anything. I read the instructions on the screen where it tells you "When you have found the correct day to press the right arrow". All this does is to move the day back. Up and right move the days back and down and left move them forward. I can't find any way to move from the date to the next stage.
    Am I being really stupid - don't answer that please :D
  5. stranger
    stranger
    ian, once on the right date click right to highlight chanel-up down to get to one you want then click right to bring up whats on that chanel (you can scroll for times) click select on any highlighted programme to record it.
    another way is while watching live tv press live tv again and you can access all chanel information from there-then click select or record button on any programme you wish to record or just browse.
  6. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    That doesn't seem to work as when I click right it changes the date again instead of highlighting the channels. I suppose that I can get around that by using a different method of selecting a program to record though.
    Maybe the software update will cure whatever is wrong :(
  7. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,917
    71
    +32
    After upgrading to v2.55.
    To perform a manual recording.
    From Tivo Central
    1. Select Pick Programmes To Record
    2. Press Right Arrow
    3. Record By Time Or Channel
    4. Press Right Arrow
    5. Manually Record Time Or Channel
    6. Choose One Time
    7. Select Day / Date
    8. Select Channel
    9. Start Time
    10. End Time
    11. Record This Showing
    12. This Manual Recording Has Been Added To The To Do List
    13. Press Select To Continue
    Obviously whilst on free trial of Tivo Service you may use easier ways of setting Tivo to record a programme but as you are fiscally efficient, I'm guessing you are investigating non-subscription manual recording, the above method is what you should see.
  8. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    What a charming way of saying that I am tight fisted :D
    It is currently running software 1.5 but when I spoke to the help desk today they said that the uptodate version should be downloaded in the next couple of days.
    Being fiscally inefficient I have subscribed today even though it is not working properly.
    What is more annoying as I am away for the next few days is that I haven't found anything worth recording.
    Thanks for your help which has been appreciated.
  9. JonMace
    JonMace
    Nov 20, 2002
    2,574
    83
    Kent
    +211
    Ian set up my parents Tivo last week, if you go into the telephone options screen you can force a call which should then upgrade the software straight away
  10. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,917
    71
    +32
    If needing to force a call.
    From Tivo Central
    1. Select New Tivo Messages & Set Up
    3. Select Recorder & Phone Set Up
    5. Select Phone Connection
    6. Press Right Arrow
    7. Select Make Daily Call Now
    8. Press Right Arrow
    Tivo will update software and guide data, simply follow on screen instructions.
