Setting up Screenplay 4805
Discussion in 'Projectors, Screens & Video Processors' started by maverick177uk, Jan 19, 2005.
  1. maverick177uk
    maverick177uk
    Jun 1, 2004
    3,786
    103
    +485
    I seemed to have eventually got my 4805 set up with the different aspect ratios so none of the picture ovelapped the screen, and then last night i watched a film through Sky and the left hand side was out of the screen a couple of inches!!
    Any ideas how I can set the PJ up so it fits everything onto the screen no matter what ratios come through? Is there any way of making say Star Wars fit the whole of my 16:9 screen so I don't get the black bars at the top and bottom.
    Cheers Rob
  2. Oakleyspatz
    Oakleyspatz
    Oct 9, 2004
    3,576
    Woking
    +231
    Unfortunately not. to reshape an image to fit you screen would involve a stretch and zoom function which the 4805 doesn't have. Even if it did, it couldn't stretch Star Wars to fit a 16:9 screen without turning Luke Skywalker in a beanpole !!! He would be stretched so much vertically that he would look about 8 foot tall and as skinny as a rake. If you stretched AND zoomed it, you'd end up losing half the image. Nope, with Star Wars being shot in 2.35:1 which is as wide as they come, you'll always have the black bars top and bottom. Look for movies shot in anamorphic 1.85:1 which fits a 16:9 screen nicely.
  3. maverick177uk
    maverick177uk
    Jun 1, 2004
    3,786
    103
    +485
    Cheers Oakley but does anyone else have the problem with Sky and what settings do you have on your 4805 with regard to keystone etc?.
  4. Oakleyspatz
    Oakleyspatz
    Oct 9, 2004
    3,576
    Woking
    +231
    Insure you have both set to 16:9. If one is set to 4:3 and the other to 16:9 it will result in a distorted or loss of picture.
  5. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,577
    Bristol.
    +321
    Yes, but dont forget that most channels broadcast in 14:9 as well as a fair few still being in 4:3. I prefer leaving my cable box set to 4:3 and watching a 16:9 PJ in 4:3 mode as this seems to hold the picture together better.
    Cap :)
