Setting up Panasonic TH37PW5B
Discussion in 'Plasma TVs' started by Hinch, Jan 24, 2003.
  1. Hinch
    Hinch
    Hi I'm new to all this and I was wondering if this setup will work:
    Panasonic THPW5B
    Onkyo Receiver with 2 component inputs and 1 component out
    Pioneer DVD656a with component out
    Nokia 221T Free to View box with RGB scart out
    My master plan is as follows:
    1. Connect Nokia box (using an RGB scart cable) to an RGB scart to component converter box.
    2. Connect output from converter box to receiver using component cables.
    3. Connect DVD to receiver using component cables
    4. Connect component out on receiver to plasma.
    The receiver is switchable so I was planning to use that to swap from TV viewing to DVD as necessary.
    Any help appreciated.
  2. jmack
    jmack
    i dont think you will have any problems doing it the way you said,
    good luck and dont forget to add a picture to the ( get ya plasma out for boys ) thread
