So ... both AV Receiver and 5.1 Speaker System? Correct?
£4000 Budget for Both ... Right?
Though only as a starting point, I would give about 1/4 to 1/3 to the AVR, and about 3/4 to 2/3 to the speakers.
So 1/3 + 2/3 =
£1333 = AV Receiver
£2666 = Set of Speakers
And 1/4 + 3/4 =
£1000 = AV Receiver
£3000= Set of Speaker
I think you can do very well for that amount of money. Keep in mind the above is only a starting point, you are free to adjust it to suit your personal taste and the equipment you find.
In that small room, I would suggest bookshelf speakers. Though it goes against my nature, if you want a more compact Speaker System, small Satellite speakers would probably be fine.
I very good speakers, consider a package built around the
Monitor Audio Silver 1 speakers -
£550/pr = Montior Audio Silver 1 Black Gloss (also black oak)
Monitor Audio Silver 1 Gloss Black Bookshelf Speakers (Pair) - Monitor Audio - AudioVisual Online - Home Cinema and Hifi Specialists
£375/ea = Monitor Audio Silver Center Black Oak
Monitor Audio Silver Centre Black Oak Centre Speaker (Single) - Monitor Audio - AudioVisual Online - Home Cinema and Hifi Specialists
£500/pr = Monitor Audio Silver FX Surround Black Oak
Monitor Audio Silver FX Black Oak Surround Speakers (Pair) - Monitor Audio - AudioVisual Online - Home Cinema and Hifi Specialists
£1450 = Total
You can get the Monitor Audio Silver Subwoofer, but they tend to be expensive. The best High-Value Subs come from BK Electronics, simply pick one that best fits your room.
Sub Woofers - Sub Bass - Subwoofer
In that small space I would recommend a 10" Subwoofer.
The
BK XLS200 in either
Down Firing (DF) or
Front Firing (FF) would probably do a find job for you and at a very reasonable cost.
XLS200-DF
XLS200-FF
That would bring the
new total to about
£1740
If you really want stunning sound quality in a reasonably compact speaker, then the
KEF LS50 would be ...well... stunning. The base 5.0 package is about £2000, then add the Sub of your choice. -
KEF Kef LS50 Monitor White AV 5.0 Package | Quantum AV
KEF Kef LS50 Monitor AV 5.0 Package | Quantum AV
That would bring your total for speakers to UNDER £2500.
The next option is very compact Satellite speaker, which would not be my choice, but is a choice that could serve you very well.
Here is a cross section of Satellite speakers -
Focal Dome Flax 5.1 AV Speaker Package
Dali Fazon 3 5.1 AV Speaker Package
Anthony Gallo ADiva 5.1 AV Speaker Package
Anthony Gallo Strada 5.1 Speaker System
SVS Prime 5.1 Speaker System
SVS are way below your budget, but are very highly rated speakers.
Bowers and Wilkins MT60D 5.1 Home Theatre Speaker System
Monitor Audio Apex 5.1 Speaker Package
KEF R Series R100 5.1 Speaker Package
In all honesty, I think the absolute best would be the
KEF LS50, these are extremely highly rated speakers.
And if placing bookshelf at the Sides is a problem, then you could substitute a pair of
LS50 bookshelf for a pair of very compact
KEF 'eggs.
KEF E301 Speakers (Pair) - Superfi
I think these could be easily wall mounted.
It is more important to have a perfect match across the Front
(Left/Center/Right) to get consistent sound. However, less so the Surround speaker at the Side/Rear. You don't want them grossly different, but most people are forced by circumstances to compromise in this area.
In your case, you room might be a bit small for the placement of Bookshelf speakers at the Side or Rear. Though I suspect it can still be done. So, an alternative Surround speaker would be workable.
Considering your budget, the
130mm (5.25") Kef LS50 fit your budget, and really are stunning highly rated speakers.
As to a Subwoofer, you are free to buy any brand or pay any price, but the
BK Electronics really are very high-value Subs, many people in this forum use them.
As to AV Receivers, with a fair budget, you have many to choose from. I think topping my list would be
Marantz. Always very highly rate for both movie sand music playback.
Marantz SR7010 AV Receiver - £1199 -
Marantz SR7010 AV Receiver - Superfi
If you want to go to a more professional grade AV Receiver, then
ANTHEM are very highly rated -
Anthem
Depending on how things work out with the speakers, you could perhaps go as high as the
Anthem MRX-720.
Here is the above
Marantz SR7010 from
Peter Tyson -
Marantz SR7010
Other than that, look at
Denon and possibly
Yamaha AV Receivers, though
Pioneer are also worthy of consideration.
Denon AVRX6200W Networked 4K Home Cinema Receiver with Dolby Atmos - Superfi
Yamaha RXA2050 Networked AV Receiver with Dolby Atmos - Superfi
With a front end of
KEF LS50, and with Surround Speaker appropriate to your circumstances, and with the
Marantz SR7010, combined with any of the
BK Electronics Sub, you should have a system beyond what you ever dreamed you could have.
I think if you check out reviews and discussions on any of these products, you will find that they are highly regarded.
Likely you can come in under budget and have money left over to pay for wire, cable, and perhaps a BluRay Player.
Let me know what you think of these suggestions.
Here is a thread where someone needed speakers with a Wide Sound Stage and he had very limited space. I recommend
KEF LS50 and provided a couple of videos related to those speakers which you might find helpful. Notice others who commented on the LS50 were very positive.
Bookshelves with Wide Soundstage?
Steve/bluewizard
