Setting up my LC26GA4E through DVI
deadred
Joined
Nov 18, 2004
Messages
2,905
Reaction score
146
Points
603
Age
50
Location
Cumbria
I've been trying to set up my laptop to run through my DVI connection but i'm having a bit of bother. I can see the screen on the tv but it's as if the image is too big to fit on the LCD screen and when i move my cursor to the left or right it "pushes" the screen out further, sorry if i haven't explained it very well, but as you may of guessed i ain't got a clue :confused:
cheers
cheers
this is normal if you have a resolution that is to high for the sharp. it doesn't scale if you have "dot for dot" mode turned on.
If your videocard can't put out the sharps native resolution, use powerstrip (progi to set up custom resolutions etc.)
Can someone give me some help using powerstrip, i've searched the web for help using the program and can't find any :confused:
Search for 'Powerstrip Sharp' on this forum. Someone has pasted the details in a message. All you do is follow the instructions (Found on a thread somewhere) and paste them in the section......apparently !
Richie.
Finally got it sorted, hell it only took me two days!!!!
RESTORATION vs. REVISIONISM: At what point do 4K video and audio 'upgrades' cross the line?
Back
