setting up my equipment
Discussion in 'AV Receivers & Amplifiers' started by krisstewart67, Jan 4, 2007.
  1. krisstewart67
    krisstewart67
    Jan 4, 2007
    88
    11
    Paisley
    Newbie here!
    I have purchased a Pioneer VSX2016 and was wondering if someoe could help me with the setup.
    I currently own a Sky+ , PC and Xbox 360, what the best way to connect all this up to give me best sound and picture?
    I wa going to plug xbox 360 into component on back of receiver, sky box into s-video on back of receiver, PC is already connected to my TV so just going to leave that. Then run a HDMI cable fromreceiver to TV to give all the picutre i need. I will then plug an optical lead from xbox, sky and pc into reciever. phew glad thats over my brain about to die! :suicide:
    Is that the best way or is there another way, which will save on cabling etc?
  2. Benny06
    Benny06
    Jun 11, 2006
    444
    +9
    thats the way'd i do it m8, tho with my denon 1907, i'd have to do it via component, but you more or less got it spot on there, just make sure you got enough and long enough optical cables etc etc they aint cheap!
    I think we're both right, if im not, please forgive me!
    Actually, u will need a optical cable from the 'opical out' from your TV to the optical in on your reciever i believe, thats how ive got mine done. I think...
