Setting up my Denon 1906, any help?
Discussion in 'AV Receivers & Amplifiers' started by LCD User, Sep 6, 2005.
Tags:
  1. LCD User
    LCD User
    About to set up my Denon 1906
    Will be running it onto my LCD TV through composite cable
    Sound will be through M Cubes and Sub
    THomson freeview- do I run this through the amp?
    DVD Player (Pio 575) will be used for movies and sound. Whats the best way to set this up?
    Also have a record player (have plugs and pre amp box from an old set up) but i see the denon 1906 does not have phone slot. Can I play it through another input? Do I use the pre amp box? I don't want to blow it up!
    Also have 3.5mm to phono for playing my i pod should tihs go through the Aux input?
    Sorry if this sounds stupid
