Setting up JS Technology RGB>VGA converter
Discussion in 'Plasma TVs Forum' started by TTurbo, May 3, 2005.
  1. TTurbo
    TTurbo
    Dec 12, 2002
    11
    Yorkshire
    Recently took the plunge and bought a Panasonic TH37PW7 and a JS Technology RGB to VGA converter.
    Fortunately the screen package included a free Panasonic scart board because I can't get the converter to work.
    I'm outputting my Sky signal to the converter via scart and linking the converter to the screen with a VGA cable and setting the screen to PC1 but can't get a picture.
    Any help would be very gratefully received.
  2. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    have you got sky set to rgb output?
  3. Unlight
    Unlight
    Jan 6, 2003
    1,524
    38
    Belfast
    +9
    Yeah thats the main cause - if you have an RGB only scart cable and the screen isnt set to RGB you wont see anything!
  4. tim k
    tim k
    Yes this is very annoying as you cant set it without seeing the sky option menu on screen, unless you have another screen which is non rgb to set it. I use my lcd pc monitor as a backup incase the rgb setting gets changed. I used to have a freeview box and everytime i turned off at mains it would reset and i would have to use the lcd to change the rgb setting, ANNOYING!
  5. TTurbo
    TTurbo
    Dec 12, 2002
    11
    Yorkshire
    Just been home to check and it is set to RGB (I've got the scart board so can check easily).
    All I'm getting is a black screen. Is there any way of checking if the converter is faulty?
    Cheers guys
  6. ukdan
    ukdan
    Feb 16, 2005
    1,135
    swindon
    +85
    Just checked my sky box, have you got an option to turn scart control on/off if so turn it on and try again.
  7. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,523
    Kent
    +830
    Checklist is:
    - scart lead must be fully wired, or at least wired for RGB
    - scart lead must be connected to TV scart on the box
    - if there is a scart switcher in the signal path, ensure it is RGB compatible (many aren't)
    - in SETUP menu on Sky select output RGB (default is PAL)
    - make sure JS box is plugged in...
    Usually its the scart being in the wrong socket on the back of the Sky box. You may still have the only RGB scart connected to the scart board and are using the VCR scart for the converter (which will not work).
  8. TTurbo
    TTurbo
    Dec 12, 2002
    11
    Yorkshire
    Cheers guys - looks like it was a dodgy lead, I tried a new VGA lead (knew that the Scart was OK) and it works now!
    Fantastic picture quality now, thanks to everyone for your help.
  9. Jono73
    Jono73
    TTurbo,
    I am about to go the very same way as you and have a VGA converter instead of the scart. Seeing that you have viewed Sky via the scart and the scart >JS> VGA path, would you say there is much difference?
    jono
  10. JulianL
    JulianL
    I'm also very very interested in the answer to this question.
    One specific question I have.... My parents have a PWD6 fed from a Sky+ box via the Scart board. I found the colour too overblown on their setup and knocked it down a bit on the panel to get a picture I liked. Knowing that the JS route will take away the ability to control the colour makes me a bit worried. How does the colour going via JS->VGA compare with the colour via the Scart board (with the panel set at it's default which is 50% I believe)?
    - Julian
  11. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    i have tried both and personally I find the colours far more realistic using the js..certainly never feel that i wish i could change them
  12. Rambles
    Rambles
    Jul 14, 2004
    8,318
    UK
    +1,288
    I always seem to get into trouble when I say this, BUT there is some colour adjustments in the user menu (not service menu) when using the JS Tech RGB to VGA converter on a PW7 panel. And it makes enough of a difference to the picture quality to be worth a mention, particularly to flesh tones (in my opinion)
  13. TTurbo
    TTurbo
    Dec 12, 2002
    11
    Yorkshire
    Sorry for the late reply, I've been busy watching TV!
    I do think that there is a noticeable difference when using the VGA converter on Sky, it's hard to define other than everything seems a bit crisper and brighter.
    One thing it does show up though is the massive variation in broadcast qualities between the different channels.
    All in all I think that for £120 it's a very worthwhile investment.
  14. w3dal
    w3dal
    Aug 4, 2002
    5,050
    Chelmsford, Essex
    +587
    Hi Lisa,
    Anychance you can PM me the details on making these slight adjustments?? from the PW7 menu should be getting my JS box tomorrow or Monday
    Dal
