Setting Up Harmoney 1000 with cheap ebay screen?
Discussion in 'Home Cinema Control & Remote Controls' started by Jer1974, Sep 4, 2007.
  1. Jer1974
    Jer1974
    Aug 15, 2006
    42
    +4
    I bought one of these screens of ebay http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=320115736145 but am having a real problem setting up my Harmoney 1000 with it. I set up a new "domestic appliance" and let the control learn the commands up, down and stop. It works but only works some of the time. Are these screens in the database? What do you think i'm doing wrong?
    Jeremy
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    the IR may be in the database try looking for make "somfy" does help fix the issue?
  3. czzer
    czzer
    Mar 2, 2005
    719
    43
    +105
    These screens are in the database...I have one myself and it works fine with my Harmony.
    One thing I had to do with mine though...
    Re-learn the up and down commands in RAW (select "Custom" on the learning page).
    When you teach it, hold the applicable button on the factory remote down for 1 to 1.5 seconds.
    If it isn't already done, go to Power Settings for the screen device and change it to "A button for ON and a different button for OFF". Set the ON command to "ScreenDown" and the OFF command to "ScreenUp".
    Then just add the screen device to the activities and it will come down when you select an activity, and go up when you press "Off".
