Setting up H/C using SPL meter...Help please
Discussion in 'Home Cinema Speakers' started by jonnyv, May 4, 2002.
  1. jonnyv
    jonnyv
    Mar 31, 2002
    2,305
    48
    +56
    I've just read a thread about setting subwoofer position and levels using various tones http://www.avforums.com/forums/showthread.php?s=&threadid=33958
    Im getting confused here...I have set all my speakers to 75db using the spl meter..The sub i lowered by about 6db as i found it too loud (also advised that the spl meter doesn't read bass very well and to lower the 75db setting of the subwoofer by about 7db)
    What exactly are the downloadable mp3 test tones for ?
    cheers
  2. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,629
    United Kingdom
    +2,233
    The test tones are to see what sort of response you´re getting from the subwoofer.
    Initially set all your speakers to 75db. Put the sound meter where your head would be at the listening position, set the meter to 70db C-Weighting Slow. Then use the internal test tones (or Test disc if you have it) and balance all the channels to 75db including the subwoofer (feel free to lower or higher this by a few db to your personal taste, mines at 76/77db).
    All my speakers are set to Small and all the bass is sent to the sub.
    Once done you can then use the MP3 tones to get readings (like you´ve done) and then its a case of playing around with positioning to get as flat as response as possible.
