Setting Up Freeview On Samsung LE23R87BDX/XEU
Discussion in 'Samsung TVs Forum' started by Stevew2, Sep 14, 2007.
Tags:
  1. Stevew2
    Stevew2
    Can anyone give me a guide into setting up the freewview on a Samsung LE23R87BDX/XEU, is it something to do with the DTV?
  2. Stevew2
    Stevew2
    anyone:lease:
  3. Curly99
    Curly99
    Dec 29, 2006
    9,426
    +2,255
    Patience is a vertu, you have to give people time to reply,
    DTV = Digital Television, for freeview, select "DMENU" on the remote, on the menu that appears select the Saterlight dish symbol, next select "auto store" then start this will start to scan and store the digital/freeview channals.
    hth, Curly
  4. Stevew2
    Stevew2
    Thank you:smashin:
