Setting up delays, and clicks
Discussion in 'Arcam Owners' Forum' started by jonjon, Jun 25, 2004.
Tags:
  1. jonjon
    jonjon
    finally, after timing my wall drilling correctly with late nights and not waking up the neighbours, the TV's been moved and my speakers are up :thumbsup: :D
    what's the best wat to set up the delays on the AVR300 and/or DV79?
    do i just do it on one or the other? ie leave DV79 at 0's and change the AVR300 or visaversa?
    or do both? :confused: :confused:
    i'm also exprienceing clicks from speakers when skipping tracks on a DVD. anyone else had this? :confused:
    i haven't checked the TUV over HDMI yet.
    cheers,
    jon
  2. MattTheBeanster
    MattTheBeanster
    Oct 23, 2003
    1,425
    Cornwall
    +100
    I get the clicks too, they are caused by the decoding engaging/changing so a dvd skipping chapters or changing from 2 channel to DD when the menu is loading will cause a click.
    Maybe they'll do an upgrade to change it. If not i'm getting used to now.
