Setting Up A Subwoofer
Discussion in 'Subwoofers' started by Ian J, Dec 2, 2001.
  1. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    Having had my Q Bass for four years I find it odd that I should be asking for set up advice now but I have recently bought a Sony 1070 which seems to have quite extensive bass management facilities.
    I have Def Tech Pro Cinema satellites and the set up sounds quite good with the sub connected to the amp by co-axial cable but I was playing around with the THX Optimiser on T2 and that has a pink noise test tone that travels down the frequency spectrum.
    There is a definite drop off in volume at the lower end of the Def Tech spectrum which increases as the REL comes into play.
    Should I be ignoring the filter on the REL and just using the variable cross over on the amp as I can set the cut off on each speaker seperately on the amp or should I be combining this with the cross over on the sub.
    Thanks in advance
    Ian
  2. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,772
    7
    2
    167
    Birmingham, UK
    +10,687
    Ignore the sub crossover - wang it up as high as it will go and use the amp's bass management.
  3. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    Will do - thanks
