I've recently bought a Morduant Short MS309 Sub. When opening the box, I found there were no instructions in there of how to put which cable where? If I bought a Sub lead, where do I have to connect it on the back of the MS309? CHEERS
If you bought a sub lead, its obviously a single phono. So using the sub output from your the back of your amp (LFE), connect to it to the low level input in the back of the sub. If you have two phono inputs (e.g. Left & Right) you can just plus the single cable to either the left one or the right, unless it states 'MONO' on either one. Hope this works for connecting up!
Will this be fine? http://www.audiovisualonline.co.uk/...amma-geometry-3m-subwoofer-cable/display.html
Use hte left one if your only connecting up the sub with one cable. Look at mordaunt shorts webstie as I think you can download the user manual for the 309. www.mordauntshort.co.uk
That would do you fine, however I would recommend the Mark Grant cable from of the power buys forum. It may be a little more expensive than the Ixos but it blew my ixos cable away and for money to.
