Setting up a LAN
Discussion in 'General Video Gaming Chat' started by hencole, Apr 8, 2003.
  1. hencole
    hencole
    I recently got BB with Blueyonder. I only got the basic package, so that whenever I want to use Xbox, MAC or PC I have to switch over the cables and unplug the modem. Now what is the cheapest/most hassle free way of setting up a LAN so that everything remains plugges in? Do I just need to use network hub or is there more to it than that?
    Cheers,
    Henry
  2. graham.myers
    graham.myers
    Mar 11, 2003
    6,220
    Leeds
    +932
    You'll need a router rather than a hub with a wlan connection to plug into BB. Search for a post I did using linksys as a search prhase - that listed everything I use for a desktop, laptop and xbox.
    the only difference would be you'd need adsl and not dsl
  3. Sinzer
    Sinzer
    May 25, 2002
    5,778
    +1,100
  4. hulkhead
    hulkhead
    Jul 2, 2002
    670
    Kent
    +11
    i use a netgear ds104 10/100 hub - which is hassle free. The pc and xbox can be used at the same time without any issues. I have a stb with ntl 600k. In the xbox network setup i gave the mac address of the nic in my pc which also uses the bb connection. It then picked up the same ip and dns settings. Works a treat and is a cheap solution..
  5. harrisuk
    harrisuk
    Jan 24, 2003
    5,322
    71
    +58
    I concur.... Router is the best option. Cheap and easy to setup.
    I got a DSL Router from www.microdirect.co.uk for about £35 which does a great job.
  6. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,187
    41
    London
    +6
    If you are buying a router for ADSL supplied through your BT phone line - make sure it supports PPP Over ATM. A number on the market at the moment claim to be ADSL routers but don't support this, making them chocolate teapots.
    Neil.
  7. harrisuk
    harrisuk
    Jan 24, 2003
    5,322
    71
    +58
    I dont know if mine supports that. But it does work perfectly on NTL broadband. I have an Xbox, laptop connected to it downstairs and my desktop upstairs. Works great.
    In any event anyone who has to use BT Broadband has my sympathy :rolleyes:
  8. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,187
    41
    London
    +6
    Well alteast BT doesn't have a 1G a day cap like NTL does !
    Neil.
  9. graham.myers
    graham.myers
    Mar 11, 2003
    6,220
    Leeds
    +932
  10. harrisuk
    harrisuk
    Jan 24, 2003
    5,322
    71
    +58
    I would class myself as a heavy user and have never come anywhere near that amount. Quite hard to use that much. If you have a legit reason they remove the cap I have be reliably told. But it is well documented that BT do restrict users upload and downloads if they find out they are using peer to peer applications. It was all over watchdog etc they just dont make it common knowledge.
    But lets cut to the chase. BT Broadband - Bad support, bad uptime. You could not pay me to use it. My work has spent the last 12 months removing ever possiblt BT service from our building they are that bad :rolleyes:
  11. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,187
    41
    London
    +6
    When I said BT Broadband I didn't mean openworld. I mean all the users that resell ADSL connections through BT phones.
    Neil.
