Setting up a dreamcast LAN
Discussion in 'General Video Gaming Chat' started by Docta teef, Jun 9, 2004.
  1. Docta teef
    Docta teef
    Nov 21, 2003
    1,257
    Manchester
    +56
    Im in the process of building a games room. Ive noticed just how cheap a second hand dreamcast can be picked up for and was concidering picking up 4 to set up a LAN with a tv screen in each corner of the room does anyone know how you would do it?
  2. supersonic87
    supersonic87
    Dec 31, 2003
    286
    Swansea, Wales
    there's no point mate, no games would recognise the 4 consoles for games to share. Them console also uses non-standard link leads and getting a hub with these would be impossible.
    However if you are looking at using more than 2 players then you'll need to use the online options of the dreamcast (dreamcast.onlineconsoles.com for help), however you'll need to use a dial-up connection or buy broadband connections (at about £100 a go).
    Rich
  3. Docta teef
    Docta teef
    Nov 21, 2003
    1,257
    Manchester
    +56
    Wont bother then when ive thought about it i want a pinball machine and and arcade cab so prob would have been short on space anyway
