Setting the Level on my Sub
nheather
I now have my first home cinema system. The sound part is made up of
Amp - Denon 1906
Fronts - Canton CD50
Centre - Canton CD50
Rears - Canton CD10
Sub - BK XLS200DF
First I tried the auto-setup. This seemed okay but I noticed on the tests that the sub sounded much quieter then any of the speakers - even so the auto setup left the speakers around 0dB but set the sub to -15dB.
As I have a SPL Meter I decided to try the set them up manually. With the SPL set to 70dB, the amp levels starting at 0dB I found the following
Speakers typically read +6dB
Sub read about -10dB
I adjusted the level of the speakers to give 0dB but when I tried to turn the level of the sub up to get 0dB it was terribly loud and thumping (not pleasent at all).
My question is ....
"How should I set up the sub - should it be set at the same level as the other speakers?"
I'd appreciate any advice,
Thanks,
Nigel
liampurcell
I dont' know the answer to this (I'd tell you if I knew), but as no-one has replied to you, try searching a bit more on these forums.
AngelEyes
Your sub will have a volume or gain on it and this affects the volume as well, not just the amp levels.
You may have the sub volume too high. I don't know about your particular sub but a lot of people (me included) run their subs at 50% or lower on the volume.
I think mine is set to 40% on the sub and +2db on the processor. Have a play and see if it improves things. If the sub volume is too high it may cause the sub to distort and 'boom'.
Badger0-0
Amp - Denon 1906
Rears - Canton CD10
Sub - BK XLS200DF
My question is ....
Thanks,
Nigel
It's either a crap sub :rolleyes:
Or you simply have it turned up too much.
Play a DD disc.
Leave everything as it is and inch the sub down until you like it.
Use your ears
Either that, or read more :thumbsup:
Job done :smashin:
nheather
It's not a crap sub, just a crap user.
Noticed I had my SPL set on 'A' weighting which means it hardly responds to sub frequencies at all.
Set the SPL to 'C' and bingo - able to set it up without problem.
Cheers,
Nigel
Badger0-0
The "crap sub" line was a joke mate, don't worry.
Glad you sorted it. :smashin:
Rocky 4K, Creed 3 and boxing movies, Shazam 2, 65 trumping Jurassic World Dominion, + Picard & Mando
