Setting the colour
Discussion in 'Projectors, Screens & Video Processors' started by AV nutter, Apr 26, 2007.
  1. AV nutter
    AV nutter
    When using line douber cant seem able to set colour using lanci line doubler just dont want to do as its told lol chris incase you ask yes read manual.mike
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,236
    +3,101
    Is it that you cannot set colour on the doubler or you cannot set colour on the projector. If the latter then that is to be expected as the scaler will be outputting rgb so colour control shouldn't apply, the colour decoding has been done in the scaler. If it is that the colour isnt working in the scaler then I would ask if has a colour control and what sources you are actually sending to it.
    Gordon
