SOUNDSTYLE
This thread is in advance of me getting either the CHT-12 or 15.
My system:
Denon 2700 processor
Monitor Audio (MA) 703 PMC (which can produce 80Hz easily)
MA Silver 3 rears
MA 750CC centre
I haven't a clue how to go about it correctly.
Will I need a SPL meter to get the correct settings?
I have a Denon 2700 processor and have all speakers set to small and all bass going to the sub.
The db for the subwoofer can be adjusted through the processor but I don't know how to use it properly.
At the moment it's at 0db (connected to a REL Q100E) and if I change the setting to -1 onwards the sub gets quieter which is what I don't want and that's why I leave it at 0.
What routine should I go through once the hi and low level connections are connected, step by step?
As the Denon has a dedicated subwoofer output and the sub has a red and white connection for low level which one should I use, or does it not make any difference?
On a slightly different subject:
Does anyone know if the Vivanco prowire (which I have connected to the REL for low level) is shielded, or should I get a better make?
If I should get a better make where should I get?
I'll need to get speaker cable for the hi-level aswell. I'm using Sonic link AST 200 bi-wire. Should I go for the same (if it's still made). I'll need 6-7 metres worth.
I haven't got any cable for the hi-level at the moment because I'm using the neutrik connection which comes with the REL.
My system:
MA Silver 3 rears
MA 750CC centre
