Setting ringtone on Iphone...
Discussion in 'iPhone Forum' started by Woodywizz, Jun 14, 2009.
Tags:
  1. Woodywizz
    Woodywizz
    Aug 18, 2005
    12,383
    Manchester
    +6,119
    Can someone give a step by step guide as to how I set a ringtone on the Iphone.
    My wife downloaded a tune on Itunes...but I am buggered if I know how to set it as a ring tone.
    Thanks in advance :thumbsup:
  2. kempez
    kempez
    May 25, 2008
    3,748
    Basingstoke
    +281
    Right click on song, select "Get Info".
    Ensure the song is set to less than 30 seconds by changing duration.
    Right click on song again: create AAC version. Right click on new copy and browse to explorer. I usually copy this file to my desktop. Delete the copy version in iTunes
    Change the copied file to file-type to .m4r. Drag back to ringtones folder in iTunes. Bingo.
    Change the duration of the original track to full length.
  3. swifty2606
    swifty2606
    Mar 21, 2008
    512
    +11
    There are some good tutorials on youtube!
  4. simon69c
    simon69c
    Nov 5, 2007
    591
    43
    Glasgow
    +100
    There are also some websites that will do all the hardwork for you for free - allowing you to upload the mp3 you want to turn into a ringtone and then just download the finished ringtone file which you can then just double click to bring into iTunes - saves all the mucking about with Get Info, exporting AAC files, finding them and renaming them etc. The one I used (as it also allowed you to create a ringtone from youtube videos) was audiko.net - easy to use and also has ringtones that others have made ready to download.
  5. Tom`
    Tom`
    Sep 19, 2008
    1,532
    Leicester
    +90
  6. CaptnSpaulding
    CaptnSpaulding
    Nov 8, 2008
    3,523
    North Wales
    +896
    I use zedge.net to download free ringtones already made so all I have to do is sync them with iTunes :smashin:
  7. pdiddy
    pdiddy
    Dec 7, 2004
    390
    +38
    Download iringer and you can make your own.
  8. OldSwitcheroo
    OldSwitcheroo
    Feb 26, 2005
    4,136
    Location, Location
    +1,046
    Can someone let me know where the ringtones for iphone folder is please?
    EDIT: It was staring me in the face... d'oh...
  9. thelurch
    thelurch
    Oct 4, 2005
    473
    +8
    Hi can these custom ringtones only be put on a jailbroken phone?
    I have been playing around with the new memo recorder app which comes with the 3.0 update.It saves as a .mp4a file.
    I have a file on my desktop and have tried to drag and drop it into the ringtone window in itunes but it wont let me, can anyone tell me how to get it recognised as a ringtone or am I wasting my time as my phone isnt jailbroken.
  10. kempez
    kempez
    May 25, 2008
    3,748
    Basingstoke
    +281
    Do what I said in my post?
  11. thelurch
    thelurch
    Oct 4, 2005
    473
    +8
    Ive done all of that but I cant get the "drag back to ringtones folder in itunes" bit to work, this is why I asked if It was only possible to do this with a Jailbroken phone?
  12. zantarous
    zantarous
    Dec 11, 2002
    2,427
    113
    +794
    :smashin: It couldn't be any simpler.
    No a phone does not need to be jailbroken to use custom tones. I just created a ringtones folder in my music library, dump the converted file in there and then in iTunes go the ringtone section and chose file -> add file and browse to the ring tone and it then adds it to the library.
  13. wbabbington
    wbabbington
    Mar 8, 2008
    2,458
    Leeds
    +284
    ^ What he said.
    Did that on my non jailbroken phone for the first time the other day and it really is the easiest thing ever. I can now have Peter Griffin 'singing' Beverly Hills Cop everytime somebody rings.:thumbsup:
  14. thelurch
    thelurch
    Oct 4, 2005
    473
    +8
    Well Im not getting it! :confused:
    It just wont let me drag the .mp4a into the ringtones folder in itunes whatever I do. Think Im going to give up as its getting late, it was a nice idea but as usual itunes makes the job too complicated to achieve easily
  15. wbabbington
    wbabbington
    Mar 8, 2008
    2,458
    Leeds
    +284
    When I used the audioko site, if you go to the 'ringtones' tab when your iphone is plugged in it should be listed there as the audioko site has already converted it to the right sort of file. Then when you sync it should appear on your ringtone list at the top under 'custom'.
  16. zantarous
    zantarous
    Dec 11, 2002
    2,427
    113
    +794
    Just run the file through audiko website, a ring tone can not be longer the 30 seconds, not sure what else the site does but all my ringtones work after being converted by it.
  17. SourKraut
    SourKraut
    Mar 26, 2004
    2,971
    Wonderful Yorkshire
    +417
    Have you tried double clicking on the file, as this works for me on ringtones I get from the audiko site.
  18. Cha1ky
    Cha1ky
    Nov 26, 2007
    49,955
    The Internet
    +24,998
    Just done one on the same site it didn't work. I wasn't beaten tho.
    So tried again and it worked.
    The problem was the ringtones were over 30 seconds long.
    So make sure any tone you're creating isn't over 30 seconds long and it should work mate.
  19. thelurch
    thelurch
    Oct 4, 2005
    473
    +8
    thanks for all your replies and patience with me! :smashin:
    Got it sorted late last night.
    The track was an 18 second voice memo of my son singing so was never over 30 seconds.
    Audiko would let me create it, but then when I tried to click on the option to download the iphone ringtone of it but it just said the ringtone you selected does not exist on the site.
    Then I tried iringer and it worked first time and automatically put the ringtone in my ringtones folder in itunes.
    I still cant manually drag an .mp4a file (less than 30sec) into itunes whatever I do but at least I did it in an indirect way!
    Thanks again
  20. Big
    Big
    Jan 3, 2006
    1,092
    Sheffield
    +160
    I found that if you right click on the file then select to open with itunes it then appears in the folder.
  21. Fontie
    Fontie
    Dec 7, 2004
    196
    Yeading
    +11
    Thanks for the iringer link it converted a custom Alarm (mp3) that ive used for years I can now use it on my new 3GS :thumbsup:
  22. Cha1ky
    Cha1ky
    Nov 26, 2007
    49,955
    The Internet
    +24,998
    +1 for iRinger.
    Just made a few tones from music i have very easy to use and imports them into the itunes ringtones folder ready for you to drag into the iphone or sync. (whatever setting you have)
  23. Mr X
    Mr X
    Aug 8, 2006
    6,908
    3
    +2,516
    Anyone with a Mac can easily edit and create custom ringtones in Garageband and then send to iTunes as ringtone.
  24. Sharpy76
    Sharpy76
    Mar 2, 2009
    4,493
    London
    +1,230
    +2 for iringer
    Tried audiko but for some reason it wouldnt upload, gave iringer a go and worked first time:thumbsup:
  25. ukbootlegs
    ukbootlegs
    Feb 7, 2006
    4,077
    Northants
    +367
    wicked site :)
    However, when I transfer the ringtones into Itunes (manual, not sync), the latest ringtone shows on the phone multiple times. And the other tones I transferred on do not appear. They all appear correct in Itunes tho.
    any ideas?
  26. loz
    loz
    Jun 4, 2001
    13,062
    +1,787
    Thanks guys.
    Those two bit of info worked a treat.
  27. jerryjal
    jerryjal
    Nov 30, 2008
    3,719
    Neither here nor there.
    +386
    +1 for iringer too, ideal for the job.
    I do have one question though, does anyone know if it is possible to change or add to the standard text alerts on the iphone? This is something i would really like to be able to do so if there is anyone with any knowledge on how to do this it would be appreciated.
    Many thanks
  28. jerryjal
    jerryjal
    Nov 30, 2008
    3,719
    +386
    Anybody have any ideas?? :lease:
  29. Cha1ky
    Cha1ky
    Nov 26, 2007
    49,955
    The Internet
    +24,998
    I believe you can't change text tones unless your phone is jailbreaked. :thumbsdow
    I wouldn't mind changing them myself too.
  30. muffins
    muffins
    Feb 1, 2008
    2,952
    +301
    1.Choose what ever song you have in your iTunes[​IMG]
    library.
    2.Listen to the song and choose a section you want.
    3.Right click.
    4.Get info.
    5.Options tab.
    6.Choose a start time.
    7.Choose an end time (no more than 30 seconds in length fron the start time).
    8.Play back, are you satisfied? Yes proceed to 9. No fine tune it then.
    9.Right click on the song and select convert to AAC.
    10.Go to recently added fined the ringtone you just created.
    11.Right click select copy.
    12.Go to desktop, right click, paste ringtone appears.
    13.Right click, select rename. rename the extension from M4a to M4r.
    14.Right click, select cut. go to you iTunes music[​IMG]
    folder find ringtone folder, right click , paste.
    15.Double clikc the new ringtone. iTunes opens and the new ringtone plays.
    16.Connect iPhone to computer, go to the ringtones tab in the iPhone. Make sure the new ringtone is ticked. Sync. Enjoy your new ringtone. [​IMG]
    You want to fine tune it? Add some fade or some silence in the end?
    1.Download Audacity 1.3 beta.
    2.If the song is bought from itunes it has drm protection.
    3.Rip it to a blank CD (preferably a rewrite one) it will be in wav now.
    4.Open it up in Audacity, fine tune it.
    5.Export it out to wherever you like.
    6.Import it to iTunes.
    7.Convert to AAC.
    8.rename extension to M4r and you know the rest. [​IMG]
