setting of my graphics card
Discussion in 'Televisions' started by skaps, May 2, 2005.
  1. skaps
    skaps
    Oct 31, 2004
    45
    could any one explain how i do the following
    "Set your graphics card to 1280x720 @60 Hz"
    ONCE AGAIN THANKS IN ADVANCE FOR YOUR HELP : :confused:
  2. philip41
    philip41
    Feb 7, 2004
    234
    16
    Sussex
    Right click the desktop, select properties, the display settings should open, now select settings, then move the slider along to the desired setting, then click advanced then goto the monitor tab and select the Mhz.
