I have purchased a pair of HomePro ZRP210 modules for use with my Harmony 895 remote.
My plan is to use one module to control the lighting and the other to switch on/off equipment that is only used during certain activities (was thinking of my sub).
I have added and paired both modules. One called 'lights' the other 'subwoofer'. I have created 4 scenes ('sockets off', 'sockets on', 'sub off' lights on', 'sub on lights off') and assigned them to each activity as needed.
However, the modules seem to remain in there toggled state when using the power off button on the remote (i.e. if the activity is using lights they remain on when everything else is switched off).
Have I set everything up correctly? Is there anyway of assigning the sockets off scene when powering everything down?
I am using version 7.3.2 of the Harmony Remote Software.
Thanks in advance.
Matt.
