Setting GAIN too high on your projector
Discussion in 'Projectors, Screens & Video Processors' started by jrwood, Aug 1, 2002.
  1. jrwood
    jrwood
    Anyone know if setting the gain too high on a projector can damage the panels?.
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,609
    Somewhere in South Yorkshire
    +6,153
    No, not on a LCD or DLP. The only effect this will have is on the projected image and is temporary ie will recover if you adjust it back again. Basically, a colour which is less than 100 bright will look the same as one which is 100% bright. ie you loose detail in bright areas. If all 3 panels are calibrated like this, a very pale grey will be indistinguishable from white. However, if you reduce the contrast setting, this has the effect of uniformly reducing gain on all 3 panels and will therefore correct the problem.
  3. GearHead
    GearHead
    I think I'm right in thinking that LCD panels are only 'stressed' when asked to block light. So if anything, increasing the gain puts a lighter load on the panels.
    Allan
  4. Gordon @ Convergent AV
    Jul 13, 2000
    14,218
    +3,073
    Depends on the device...
    With CRT or Plasma (yes I know it's not a projector) you can trash them.
    With DLP I am led to believe that with some models solarisation may occur. This won't damage anything just look crap.
    May get same effect with some LCD's but I've not tried it yet...
    Gordon
  5. tahustvedt
    tahustvedt
    Feb 11, 2002
    112
    19
    In a galaxy far, far away... (Norway)
    GearHead is correct. increasing the voltage to a pixel of a LCD-panels blocks more light.
    Tor Arne
