setting crossover frequency. on a onkyo 608
Discussion in 'AV Receivers & Amplifiers' started by summerof58, Jan 12, 2012.
Tags:
  1. summerof58
    summerof58
    Jan 12, 2012
    9
    trying to set my crossover frequency need help
  2. davepuma
    davepuma
    Jun 24, 2004
    17,529
    +3,506
    What do you need help with? There is a sticky post at the top of the AVR Forum re. bass management. That is a good place to start. There is also an owners thread for your receiver HERE. Ultimately if you need some help, you are going to have to be more specific as "need help" doesn't give us much to go on. Give as much information as possible e.g. speakers, frequency response if known etc.
  3. summerof58
    summerof58
    Jan 12, 2012
    9
    my speaker set up is a acoustic research down firing 250 watt. older bose 10.2 standing speakers. 2 bose back speakers 100 watt. and a 100 watt jbl center channel. speaker just didn't know. to set my front speakers at full band i bought the onkyo 608 used hope this helps some.
  4. davepuma
    davepuma
    Jun 24, 2004
    17,529
    +3,506
    Check the frequency response for each speaker and set the lower figure as the crossover.
    If in doubt, set the speakers to SMALL and the crossover to 80Hz but to be exact you're going to have to check the specifications of your speakers in their manual.
  5. scottthehat
    scottthehat
    Jan 6, 2012
    11,160
    2
    167
    honiton
    +2,799
    as dave said above and do you have a sub if so set the lpf to 120hz, and if its amplified set the freqency to full and the volume to suit your needs.
  6. durzer
    durzer
    Aug 12, 2008
    64
    My manual gives a rough guide due to speaker size. Wouldn't auddysey sort it out for you?
  7. summerof58
    summerof58
    Jan 12, 2012
    9
    my audssey quit working just was trying to get a opinion on my bose 10.2 floor standing speakers. to set at full band or 80
  8. dante01
    dante01
    Mar 5, 2009
    44,870
    +10,545
    It is generally advised to define all speakers as being small and use a crossover cutoff regardless of the physical size of your speakers. 80Hz is a commonly used crossover and a good place to start.
  9. summerof58
    summerof58
    Jan 12, 2012
    9
    thanks will try just new to all this just thought since these speakers have good bass they could be set at full band but have to try the 80 htz
  10. summerof58
    summerof58
    Jan 12, 2012
    9
    to me it sounds better when i have mains on fullband & double bass
  11. summerof58
    summerof58
    Jan 12, 2012
    9
    found manual for sub it says lowest crossover for it is 80 hz. & 450 max watt. my 2 bose back speakers are 161 & jbl hls are center
  12. scottthehat
    scottthehat
    Jan 6, 2012
    11,160
    2
    167
    honiton
    +2,799
    what sub is it.
    set the amps lpf to 120hz and set the sub woofers amp cross over frequency to as high as it goes or atleast 120hz.
  13. summerof58
    summerof58
    Jan 12, 2012
    9
    it is acoustic research. sub
  14. summerof58
    summerof58
    Jan 12, 2012
    9
    i do have. it set at 120 with the crossover as high as it goes everyone says set the mains at small but have them at fullband & double i
    lbass function
  15. scottthehat
    scottthehat
    Jan 6, 2012
    11,160
    2
    167
    honiton
    +2,799
    i have played about with mine and have my rears and back rears and center on 80hz and my fronts on full band like you with db and i have a 15" wharfdale sub which i have replaced the driver with an audiobahn 600w rms sub and it sound sweet.
  16. summerof58
    summerof58
    Jan 12, 2012
    9
    thanks for the reply glad i am not the only one that does that. i know everyone has there own setting
