setting clock on pdp-504hde
Discussion in 'Plasma TVs Forum' started by dvdsubtitles, Sep 7, 2004.
  1. dvdsubtitles
    dvdsubtitles
    Hi chaps,
    I've just realised that every time I turn on my 504 - using the power buttons on the screen and media box - I have to set the clock.
    I've been disconnecting it from the mains a lot recently while setting up the screen and components, so I didn't take much notice. Now I've realised that it happens when the mains is always on, but I switch on and off using the power buttons.
    This can't be right can it? Has anyone else experienced this problem?
    Regards,
    Mat.
  2. superga1999
    superga1999
    Aug 14, 2004
    62
    +6
    Yes I'm seeing the same thing. My kit is new and like you I was unplugging the equipment so thought it was that - but it loses the setting just when switching off using the remote.
    It should keep the time as it's becoming quite annoying! Anybody any ideas?
  3. dvdsubtitles
    dvdsubtitles
    I vaguely remember seeing a setting somewhere that says "clock from program" or "time from program" or "time from channel" or something, and you specify a number. Are we supposed to set it up to pick up the time from a specific input/channel? I can't remember if this setting was in the tv or digital box.
    Unfortunately I'm not at home at the moment to fiddle about :(
    Mat
  4. dvdsubtitles
    dvdsubtitles
    Right, I contacted Pioneer service and they said that it is a known fault and that they will come and replace the media box asap if you report it. Apparently the media box is covered by an unlimited warranty, so does not matter how old it is. They've agreed to come and swap the media box for me as soon as thursday. Impressive!
    Cheers,
    Mat.
  5. PC Nut
    PC Nut
    Jan 11, 2004
    648
    South West
    +64
    Had the same problem here, media box swaped to one that had a newer software version fixed the problem for me.
  6. spikeyboy3
    spikeyboy3
    SOunds like its time for a call to Pioneer then - this has been bugging me for ages :)
    Spike
  7. PC Nut
    PC Nut
    Jan 11, 2004
    648
    South West
    +64
    It bugged me too, but sorted now.
  8. alexed
    alexed
    Has anyone had these probs with the PDP 434HDE?
  9. vhaines
    vhaines
    Yes - I'm having the same problems with my 434HDE. Bl**dy annoying!
    Vince
  10. dvdsubtitles
    dvdsubtitles
    Its exactly the same media box isn't it?
  11. dvdsubtitles
    dvdsubtitles
    Quick update.
    Plasma media box replaced on the second attempt (yesterday). They brought the wrong box last week - they brought the box for a 3rd generation (pdp-503) by mistake.
    Nevertheless, I had a good fiddle about last night. It seems the problem is only partially resolved. Once set, the unit keeps the time when left on standby (ie. switching off with remote) but still loses the time when switched off by the main power buttons.
    This is an improvement, as previously I had to reset the time even after leaving the system on standby.
    However, the engineers left a note (I wasn't at home, my wife was there to receive the box) saying that they were unable to set the time because there was no aerial input.
    This is very interesting - I have my aerial cable going straight into my freeview box, and atm I have no pass-through to the plasma media box, so the plasma media box gets no aerial signal. It seems that the TV needs a terrestrial aerial signal to pick up the time automatically. So I temporarily put the aerial cable into the plasma media box, ran the auto installation function and hey presto, it picks up the time!
    Mat
