Settin up Xbox Live Help
J
jooooony!!
right i understand any of this stuff, but im getting xbox live for xmas
so what do i need so i can actually set up, i need to buy a router dont I?
what else do i need, please someone help
thanks :):) joony
Kimafy
Hi, you're gonna need an ethernet cable to connect xbox to PC/router, cable comes with the 360, or if you wanna go wireless you have to buy the 360 wireless adapter £59.99 which plugs into the USB at the back of the xbox. Once youv'e connected everything turn on xbox and select join xbox live at the dashboard, follow on screen instructions. Good luck!
Batch
