Sets that can be switched between 50hz and 100hz
Discussion in 'Televisions' started by blackbull, Oct 22, 2003.
  1. blackbull
    blackbull
    Hello everyone,
    On this long and winding road to AV heaven my next step is hopefully a new TV in about 18 months!! What I am interested in is the flexibility of a 100hz set so as to be able to play games via Xbox, etc in NTSC or PAL at 50hz or 60hz (depending on source of game obviously) and the TV viewing picture of a 50hz set (I am lucky enough not to see the flickering before anyone gets started) Are there any manufacturers who allow you to switch between both modes with no problems? Progressive scan is also a must!!
    Thanks in anticipation
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    the 100hz bits of almost all 100#hz sets can be turned off.
  3. blackbull
    blackbull
    I have a Panasonic 100hz set, the TX28PL10 and I didnt realise I will look at my manual again will the picture lose the "100hz look" simply by switching the these things off?
  4. HowieC
    HowieC
    Jun 9, 2002
    249
    London
    Sorry to disagree but the majority of 100Hz sets cannot switch to 50Hz.
  5. Kevo
    Kevo
    Aug 23, 2001
    5,358
    Manchester
    +145
    My Tosh RP 40WH08B cannot switch from 100Hz either.
    The same that goes for other Tosh models (inc CRTs) made at the time. They (and mine) have 'natural scan' as an alternative which is still 100Hz.
    Don't know about more recent Tosh models though.
  6. PaulJ
    PaulJ
    Hello,
    Generally the sets that can change from 100hz to 50hz, seem to be the higher end specifications.
    The Sony FQ80 and the DRC models can be reduced to 50hz and my previous set, the pixel plus 9527 had this faciltiy as well.
    I currently have a FQ70 100hz and this cannot be reduced to 50hz.
    Not sure about other models.
    Hope this may be of assistance.
    Regards
    Paul :smashin:
  7. blackbull
    blackbull
    Thanks for the info guys
  8. Dave20
    Dave20
    my sony fs76 can switch from 100 to 50
  9. jdg
    jdg
    Using the pannys internal Progressive Scan, setles it to 50 Hz. Acuity is 70 Hz
  10. blindlemon
    blindlemon
    <pedant mode>
    75 actually ;)
    </pedant mode>
    Sorry :)
