Setanta Question
Discussion in 'Freeview & YouView' started by gaz010, Jan 18, 2008.
  1. gaz010
    gaz010
    Sep 5, 2007
    41
    Hi all
    What happens if you take out the monthly subscription and things works out ok.
    But then you have a power cut or you turn off your box by mistake for a few hours. Will you still stay connected to setanta or will they disconnect you as the box has been turned off?
    Ta Gaz.
  2. kbj242
    kbj242
    Sep 23, 2005
    526
    28
    +32
    The box being off for a few hours shouldn't alter anything...AFAIK
  3. derek500
    derek500
    Dec 23, 2007
    3,746
    103
    +497
    Your subscription data is held on your viewing card. You can turn your box on and off as often as you like.
