Set up the projector to dvd etc
Discussion in 'Projectors, Screens & Video Processors' started by POPPY, Dec 19, 2004.
  1. POPPY
    POPPY
    Dec 19, 2004
    26
    3
    ok
    I am new to projectors, thinking of buying epsontw10h, any body answer these questions
    1 How do I connect ot dvd from one end of room to other
    2 Can I position projector on table if so what height
    3 What kind of picture quality can I expect
    thas it for now
    Thanks :blush:
  2. Oakleyspatz
    Oakleyspatz
    Oct 9, 2004
    3,576
    Woking
    +231
    1)You can either have the DVD player close to the projector and run a short S video cable or component cable to the projector and a long coaxial cable to your amp from the DVD player, or have the DVD close to the amp and run a long component or S video to the projector.
    2) You can indeed place the pj on a small coffee table so long as the line of sight to the chosen screen/wall is not obstructed by anything. I would say that from a coffee table the bottom of the image would be about 3-4 foot off the ground.
    3) Picture quality would be very impressive if this is your first pj, but only if used in a completely dark environment. Daytime pj viewing is not recommended. I would say it would be similar to a 90inch Plasma which of course you cannot get so I would say...darn fine image !!!
  3. POPPY
    POPPY
    Dec 19, 2004
    26
    3
    thanks for yoyr reply
