Set up question
Stumpywhu
Established Member
I have a denon 2803 and 6 B&W VM1's plus a Rel Stampede sub.
The fronts are in the corners of the room approx 12 feet apart and the same distance away from me.
The surrounds are either side with the rear a few feet behind.
My 'problem' is that although the sound is all there and sounds great, there is no real 'soundstage' to it.
The effects are definately audible but its not obvious where they originate and go to if you follow.
Rather than give a specific reason, I would just appreciate advice as to where where I should begin investigating to improve this i.e change individual speaker levels (I have played with these a bit to try to 'cure' this) or whether I should move the fronts closer together (which seems odd when trying to improve separation).
Any suggestions are welcome.
Thanks.
Tribit StormBox Blast Bluetooth Speaker: Review Coming Soon
