Set-up question - too many cables?
Discussion in 'Cables & Switches' started by Zepfan, Aug 24, 2005.
  1. Zepfan
    Zepfan
    Oct 24, 2003
    62
    The front end of my A/V system consists of DVD player only (i.e. no other inputs). I am using component cables to connect to the projector directly.
    However, reading the instructions for my processor it suggests that I run the component from DVD to processor and then out to the projector. Is this necessary/desireable if I only have one input? Do I lose quality if I run through the processor first?
    I assume it would only be necessary to run through the processor if I have more than 1 input for my system. Or am I talking rubbish!
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    A direct path will always give the best quality signal.
