Set-up question Jamo DV50
Discussion in 'Home Cinema Buying & Building' started by Ukkel1, Sep 24, 2004.
  1. Ukkel1
    Ukkel1
    This might be a dumb question. In the set-up for the DV50, i can set the levels for the 5 Jamo 325 speakers. They are all set to +5.(you can set them from -5 to +5) What is the function and what/how should i do this?
    Ukkel1
  2. quattro
    quattro
    Nov 30, 2003
    389
    Stafford
    +16
    The purpose of this is to adjust the speakers dependant on where they are situated, if for instance they are all placed in the optimum places and seating arrangement is also optimum then you shouldn't need to adjust anything. If however they can't be arranged in the optimum places due to size of room and seating ect the speakers volume can be adjusted so that better acoustics can be gained basically increasing the loudness up or down.
    To set this up can be done through the setup menu under speakers.
    Quattro
