Set up help
cu_jimmy
Just gor a new sony dvd recorder and dont know how best to connect it to my sky box and tv,can any of the more expeirenced guys who use this forum help me out.
My tv is also a sony and has 3 scart sockets.
(1) RGB
(2) Smartlink...Not sure if this is RGB....I dont think it is.
(3) S-Video.
My sky box is a panasonic and has 2 scart sockets.
(1) TV Scart.
(2) Video Scart.
My DVD Recorder is the Sony 510 and it has two scart sockets also.
Any help would be gratefully appreiciated.
tobyjuggler
Established Member
If you want the best quality recordings you'll need to use RGB, so it might be best to connect:
Sky Box TV Scart to RGB input on DVD Recorder, then RGB output on DVD recorder to Scart 1 (RGB) on TV.
Problem is that it'll mean you'll have to have the DVD recorder on to watch Sky in the best quality through your TV, unless it passes through the RGB signal when it's in standby. Give it a go and see.
johnmccoy
tobyjuggler is totally correct. The RGB input on your recorder is marked as Line3 on the back. You do not have to keep the player on - it passes RGB through as long as it is plugged in. I have the same model and Sky+ it it all works very well.
cu_jimmy
Thx guys,im up and running now,first immpressions are excellent,before i got my recorder i i thought i had a good picture but now the colours seem to have come to life,i just need to learn how to operate my new toy now.
Thanks again for you help.
SVS Prime Wireless Pro Powered Speakers - Review Coming Soon
