Set Up Help!!
Discussion in 'Cables & Switches' started by LMD, Jan 2, 2005.
  1. LMD
    LMD
    Dec 15, 2004
    231
    +5
    Evening all.
    What is the best way to connect the following kit to get the most from it: -
    - Toshiba 36ZP46 CRT TV
    - Pioneer 575 DVD Player
    - Sky+ Box
    - Xbox (un-modified)
    I plan on using the prog scan functionality on the TV and DVD player so have assumed thus: -
    1) DVD Player to TV
    Compontent video cable + digital cable for audio
    Am I right to assume that component video does not handle audio? Furthermore are there any differences in performance between optical and coaxial digital cables??
    2) Sky+ Box to TV
    RGB Scart lead
    3) Xbox to TV
    Currently using supplied leads but have found the following IXOS cables online...
    http://www.hifistore.co.uk/category.php?qsCat=XBOXCAB
    Will these improve picture quality over the supplied leads and if so which is the best option for an un-modified Xbox taking all other connections into account? I was thinking of going with the Scart option to keep things simple.
    Apologies if I sound a little wet behind the ears but I have recently upgraded from a 10 year old Sony 29" TV using simple scart connections and am just getting up-to-speed with things :blush:
    I intend using QED cables where possible (any comments??).
    Thanks in advance for any advice :thumbsup:
  2. GreenBars
    GreenBars
    Oct 29, 2004
    631
    Hertfordshire
    +23
    1) Component should be the best way to connect the DVD to the TV (and the only way to utilise the progressive scan function). You're right, it doesn't handle audio - not sure which would be best out of digital or co-axial though.
    2) RGB is the best for Sky to TV.
    3) Assuming that this is an RGB cable it should give the best picture - I'm sure there must be cheaper, yet just as good, alternatives though.
