set up discs
Discussion in 'Movie Forum' started by monitor, Apr 1, 2001.
  1. monitor
    monitor
    i have just got a DD/DTS system and i have been told of set up discs you can get to get the best picture and sound out of your set up .can anyone help with this , have you used one ,what are they like , and where do you get them
    please help
  2. Black 5
    Black 5
    Jul 19, 2000
    367
    19
    Isle of Man
    +3
    You can get the Avia or Video Essentials dvds from most R1 suppliers. They will help you get the most out of your picture - experimentation is usually the best way to sort out sound since room size, speaker placement, personal preference, etc are big factors in setting up.
