Set up disc???
Discussion in 'Plasma TVs Forum' started by Mowlith, Feb 27, 2005.
  1. Mowlith
    Mowlith
    Dec 22, 2004
    47
    Hi... I have read in the past that there is a disc you can get that you run through your DVD, and it helps you set up your screen settings, from what I remember reading there are two that are very good but I can't find the thread I read it on.
    Can anyone help me with some info on what it is called, or where I can get one.
    Thanks very much in advance for any help out there. :thumbsup:
  2. Noodle
    Noodle
    Jan 6, 2003
    577
    Peterborough
    Search for 'Avia' or 'digital video essentials'
    I think play.com sell DVE or if you fancy it, join lovefilm.com as they have a copy that they rent out. You get a free trial when you join anyway.
  3. Mowlith
    Mowlith
    Dec 22, 2004
    47
    Thanks for your quick reply, I will do some internet searches...
    again thanks for your help.
  4. Bearded_Malc
    Bearded_Malc
    Aug 10, 2004
    393
    +20
    Avia and DVE are being sold as power buys on these forums. The DVE was cheaper than anywhere else I could find. The reviews I read recommended DVE over AVIA so I didn't price the AVIA. BTW price is still the same as I've just ordered a DVE.
  5. geewhizz
    geewhizz
    Jan 2, 2005
    2,437
    +89
  6. Mowlith
    Mowlith
    Dec 22, 2004
    47
    Hi Guys....
    Thanks for the reply's... apart from the power buys on this forum, I have found DVE at Play for £14.99 delivered.
    Or I have found DVE PAL for £10.35 and DVE NTSC for £10.45 delivered on Amazon.co.uk
    Just thought I would share it with you.
