(Servo 15) X30 question
Discussion in 'Subwoofers' started by chris, Jul 17, 2005.
  1. chris
    chris
    Nov 20, 2000
    1,226
    romney marsh, kent, uk
    +28
    This post is aimed at the many people on here that use duel servo15's.
    Do you use the X30 unit with them.....????
    If you do, do you leave the PSU switched on constantly....???
    Because of where mine is plugged in, it is a pain to keep switching it on and off.
    Just wondered what the lifespan of the PSU would be if left on constantly and is it easy to find a replacement for it once it goes.
    Are there any other alternatives than the X30, that have a better PSU setup.
    At the moment, when i want to watch a film i have to struggle to turn the X30 on, then turn the subs on ( cannot seem to get the auto on to work at the moment ) and then when it's finished i have to do it all again in reverse.
    Cheers....chris.
  2. stranger
    stranger
    May 29, 2003
    2,250
    5
    117
    Manchester
    +758
    My X-30 psu has been on for the last 18 months
  3. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,906
    71
    50 Rue St Georges, Paris.
    +32
    Mine has been left switched on for nearly three years.
    I think it will be OK like this - the risk it will fail if I switch it back on after turning it off whilst on holiday or whatever is more of concern to me.
    Everything I have left switched on - in one or two cases - more than 16 years - has been fine. The odd power supply failure suffered has happened to things I have switched off for a while - then switched back on - I was told that capacitors dry out and become brittle - causing them to fail when disconnected/reconnected.
    Whether power supplies would last longer if turned on and off every night - I have no idea. Like many - I leave things connected as they seem to work better whilst warmed up - Naim amps - and stuff.
  4. chris
    chris
    Nov 20, 2000
    1,226
    +28
    thanks for the replys.
    I'll leave it on and see what happens.
  5. kbfern
    kbfern
    Aug 17, 2002
    17,798
    Wolverhampton
    +5,960
    Chris
    Did you get that second sevo 15 yet,1 was sold to a chris on ebay a few days ago was it you? it was from Brum, I could have brought it down for you when I picked my SVS up from you.
    By the way I am so pleased with the SVS its awsome man,nearly shat myself with Flight of the Phoenix I thought the walls were going to come down, and the pressure in the room!!!!!!!!
    Anyway if it was you with the second servo,whats it like,have the people next door complained yet?or have they put their house up for sale.
  6. chris
    chris
    Nov 20, 2000
    1,226
    +28
    Yes that was my second one.....
    they are sounding and looking good, but need a bit more setting up.
    When i get the chance i have got to wire up my BFD and i've also just got 2 auralex gramma platforms to put them on.
    The nighbours have not complained yet, but then i have not had anything on nice and loud yet.
  7. Smurfin
    Smurfin
    Aug 13, 2002
    21,422
    +4,354
    what made you change chris?
  8. chris
    chris
    Nov 20, 2000
    1,226
    +28
    just fancied a change.....got board looking at the dustbin in the corner.
    Could not afford a DD or the 850 and thought i would give a duel sub setup a try, so the servo's are the next best thing IMO.
    Would like to know what the price is of the new servo15, but i bet it's out of my price range.
    Was looking on an Ozzy web site the other day and they are still selling the original Servo at the equivelant of £1500.
    Always was and always will be a good buy in the UK.
