M
morg
How audible is the hum on this subwoofer meant to be. Just got
one on sat. When plugged in I can hear the speaker cone humming from the other side of my room which is about 12ft
long. The humming gets worse when I atatch the phono lead.
(its only a cheap phono which I am going to replace)
Also when using the 100-20hz tone on Avia disc with the volume
control at halfway the sound output stops from 30hz downwards
Would the cheap phono cause this or is it just that the volume
needs to be higher to hear it down to 20Hz.
Thanks in anticipation
Morg
Morg
