services menu - signal strength
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Joe Pineapples, Mar 8, 2002.
  1. Joe Pineapples
    Joe Pineapples
    Oct 23, 2001
    7,571
    Doncaster
    +1,259
    Anyone checked the (skydigital) services menu/system setup/signal strength lately? - mine has dropped a fair bit, though the signal quality meter has stayed what its always been.
    actually thought it was a by-product of trying another digibox, but its the same on the old one.
    btw - can the LNB deteriate over time, and produce a weaker signal?
    cheers
    dean
  2. gbmitie
    gbmitie
    Apr 25, 2001
    1,167
    49
    republic of ireland now
    +70
    As long as u are getting a good picture I would not worry but LNB' s can get faulty/dirty. Also make sure lead is secure.
    gbmitie
  3. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    Signal stength on all three of my LNB outputs are much the same as they were last year.
    No doubt a LNB can deteriate over time but I would be surprised if it was noticeable before it failed all together.
    Dirt/grime could produce the same results not to mention even a slight misalignment, over X amount of years the obvious weakness is in the cable and the interconnects I would have thought.
  4. Joe Pineapples
    Joe Pineapples
    Oct 23, 2001
    7,571
    Doncaster
    +1,259
    thanks
    picture is/has been fine, though i do suffer from the occasional few seconds picture break/lockup. My neighbour (2 doors away) has been suffering from lockups quite badly recently.
    cheers
    dean
  5. SignalMan
    SignalMan
    Mar 8, 2002
    349
    West Yorkshire
    +22
    Signal Strenght, why should I want to, don't let it worry you it's quality that counts (so they say):) LNBs like all electronic equipment do fail but it's generally down to poor install, not tightning your nuts properly and so on, but seriously if you have 50% or above signal and quality on the signal test, then generally speaking it's fine
  6. gges
    gges
    Signal strength indicator is very inaccurate - as long as it works - don't worry. LNB's do fail - when they do you will get lock ups and freezing etc. If you have a Grundig receiver then it could be faulty - becoming quite common. Easily and quickly repaired fault though.
    Rgds. GGES.
  7. rigman
    rigman
    Dec 14, 2000
    2,969
    83
    East Yorkshire
    +115
    There has obviously been a lot of adverse weather lately maybe your dish has shifted a tad enough to drop down the signal strength indication but not enough to affect the picture too much.
    Darren
  8. Lex
    Lex
    Feb 7, 2002
    4,089
    61
    Cornwall
    +4
    I actually found the signal strength meter to be quite accurate - we installed our satellite dish using only this and a compass.
    What sort of level is most people's signal strength meter showing?
    I have yet to see one more than three quarters high.
    They also tend to fluctuate during adverse weather conditions as well (especially heavy rain).
  9. SignalMan
    SignalMan
    Mar 8, 2002
    349
    West Yorkshire
    +22
    GGES and Darren are wright it coulde be a mixture of both or maybe your tele is leaning to one side, try propping it up with beer mats. Like I said it don't matter if the picture is OK
  10. delta
    delta
    Oct 16, 2000
    469
    16
    North East Cheshire
    30% strength, 20% quality but it is still an excellent picture although I wonder if I should try a realignment especially as I lose the whenever it rains into the dish.
  11. SignalMan
    SignalMan
    Mar 8, 2002
    349
    West Yorkshire
    +22
    Hi David
    Iwould certainly try re-aligning as it should only drop of when the weather is really bad, rain should not affect the picture but a really bad downpour will cause drop of and pixelating of picture. As stated before, a lot of the time it's down to bad installation when the installer does'nt take enough time to align the dish correctly. The trouble is if you pay peanuts you get !!!
  12. Joe Pineapples
    Joe Pineapples
    Oct 23, 2001
    7,571
    Doncaster
    +1,259
    Going to ring someone tomorrow to check alignment on mine - got to get them to align another dish with sky satellite position anyway, so i'll use the "you couldnt just.....while you're here" :)
    Dean
  13. gbmitie
    gbmitie
    Apr 25, 2001
    1,167
    49
    +70
    I use a quad LNB with an 60cm dish and signal strength is off the scale, a solid white line, quality is about 90%. Use a PANA, PACE, AMSTRAD. LNB is 0.5db, cable length, about 30 feet with very few bends.
    gbmitey
