service packs SP1 & SP2
Discussion in 'Desktop & Laptop Computers Forum' started by andrewq, Apr 19, 2005.
  1. andrewq
    andrewq
    Dec 18, 2004
    54
    Just got a new computer and when it came to loading the USB2.0 drivers from the motherboard disc it told me to install SP1 as the drivers are included in this service pack. Do I really need to install both SP1 & SP2 or will SP2 do everything in one go? Or could I get the drivers elsewhere?
    Thanks for any help
  2. RobsterD
    RobsterD
    Dec 11, 2000
    891
    Southampton
    +12
    Yes install SP1 first and then SP2.
    Tho check what you have in control panel/system a "new" PC would have these updates.
  3. stlic
    stlic
    Feb 17, 2004
    762
    +19
    SP2 contains all the updates from SP1 so only need to install SP2.
  4. kolabere
    kolabere
    Feb 8, 2005
    419
    +7
    Correct it is unnecessary to install both SP1 and SP2, just do SP2.
    However, since this is a new PC you would be advised to slipstream SP2 onto a new bootable Windows CD - this is a much 'cleaner' installation than adding SP2 later.
    A good guide to this is Paul Thurrot's site.
  5. RobsterD
    RobsterD
    Dec 11, 2000
    891
    Southampton
    +12
    Well I stand corrected but when I tried that it screwed my install of XP pro,only solution was XP disc,SP1 then SP2 :confused:
  6. stlic
    stlic
    Feb 17, 2004
    762
    +19
    I'm surprised Rob, I've done multiple installs of SP2 on non-SP versions of XP, Home and Professional, without any issues. The only time I had a problem was when trying to update a particularly poorly kept months old install of XP.
