Service mode codes for Samsung Plano WS-32Z78R
Discussion in 'Televisions' started by DeckardCaine, May 7, 2003.
  1. DeckardCaine
    DeckardCaine
    I am looking for codes to enter service menu on my bran new Samsung WS-32Z78R. Just need to adjust convergence and left vertical pin ballance slightly. Maybe some other Samsung WS Plano codes work. Please help. Thank You.
  2. DeckardCaine
    DeckardCaine
    Found it !!! Just like with some other models (in standby mode press in order INFO - DISPLAY - MENU - MUTE and than power button to turn TV on). There is a million of very usefull parameters and also reset switch to reset values if something would gone wrong. Most geometry options are self explaining. Excellent. Did adjusted geometry as perfect as it should be. Now the TV is almost perfect to me.
