Service Menus for Tosh 32WD98B
Discussion in 'General TV Discussions Forum' started by Matthew Attoe, Dec 18, 2001.
  1. Matthew Attoe
    Matthew Attoe
    Dec 8, 2001
    702
    Norwich
    +11
    Hi guys,
    Does anyone know how to get into the service and other special menus on a Tosh 32WD98B Widey?
    The set has a few slight geometry problems which i would like to correct.
    I have never done anything like this before, but i'm not stupid and think that I could, with the advice of some of you guys, be able to complete this task.
    Some hints & tips i have already picked up are:
    Leave the set on for an hour or so before doing anything.
    write down the original settings, so that if it does go wrong I can get back to where i was.
    Anything else I should know?
    Matthew
  2. Doubledoom
    Doubledoom
    Check google under the uk.media.home-cinema newsgroup and do a search for "toshiba service menu".
    This will give you loads of info about how to get into the menu and lots of comments and suggestions.
