Service Menu?
Discussion in 'General TV Discussions Forum' started by Riviera, Dec 27, 2001.
  1. Riviera
    Riviera
    Hi, I've just got a Thomson Wide Screen TV - a 28WR25EG according to the paperwork. I'm quite happy accept for a couple of nagging points.
    1. On some broadcasts there is a black band down the right hand side of the screen.
    2. Although the picture fills the screen it seems to miss off the picture edges. For example, when a programs credits are rolling it will miss of the first and last letters when the credit lines are too long. It's like the TV has zoomed in a bit on the picture. When playing from DVD there is no such problem.
    3. The picture sometimes seems off-center.
    I am getting my TV signal through an NTL digital box and have set that up for wide screen mode, 16/9.
    Is it possible to correct this through the service menu as I have seen in the past with other TV's? If so, how do you get the service menu up?
    Cheers,
    Riv.
