Service menu Toshiba 3327?
Discussion in 'General TV Discussions Forum' started by ianjh, Dec 22, 2000.
  1. ianjh
    ianjh
    Does anyone have any idea how to access the service menu (if there is one that is) on my 8-9 year old Toshiba 3327DB 4x3 set.
    thanks
    ianjh
  2. Demon
    Demon
    Dec 13, 2000
    1,025
    Cheltenham
    +83
    I think, if my memory serves correctly, try holding down 'F' and the video input button, the circle with the arrow going into it onb the remote control, this dhould then allow you to enter the code '1023', on the screen, on entering this, you should be in engineering mode, hold 'F' and then the picture/sound menu buttons to change modes, plus I think 'f' and the number keys give some feature, '2' should give the attraction mode, this was pretty nifty, and I lovwed doing this in curry's, ahhhh, those were the days....
    If this doesn;t work then you have the newer chassis model, so its erm, Damn, I can't remmeber, I think you press menu on the set, and call on the remote, I am sure others can help you there....
