service menu panny pw5
Discussion in 'Plasma TVs' started by GuitarGray, Jan 15, 2003.
  1. GuitarGray
    GuitarGray
    does anyone know if it has 1 and how to access it please
    i bet a lot of ppl would like to know..i am one..
    any help or private messages greatfully recieved :)
    Graeme
    grayhope@hotmail.com
  2. nickt
    nickt
    Graeme,
    Try a search for "service manual" - I'm pretty sure that the URL for it is in a thread already and the info should be in there (it is for the series 4)
    Nick
  3. toonarmy
    toonarmy
    May 23, 2002
    226
    Dumfries
    +6
    This works on the Panny 4 series and i have been told it also works on the 5 series.
    Right here we go.
    Press and hold the volume - button on the front panel of the screen and then press the recall button (this is the button directly underneath the red on off button on the remote) 3 times quickly (within 1 second).
    You should get a screen showing 4 modes select SD mode and prees action on the remote.
    The number beside the PT is the usage in hours.
    To exit press the R button highight ID mode and turn off the power switch on the panel.
    Be careful what you are doing as you could void your warranty if you change settings and mess things up.
    Toonarmy
