Service menu on Toshiba 42PW23P anyone?
Discussion in 'General TV Discussions Forum' started by JIT, Jun 18, 2002.
  1. JIT
    JIT
    Mar 2, 2002
    1,188
    38
    Glasgow
    +8
    Could anybody give me some information as to how to access the service menu on this set. It's like the 42WH18B but without 100Hz and DD5.1.
  2. Oblivion
    Oblivion
    Feb 23, 2002
    524
    Milton Keynes
    Try this
    Press and release mute on the remote
    Press and hold mute on the remote
    While still holding Mute press menu on the front of the TV
    The above works for my 28 Tosh
    Hope this of some help
    Paul
  3. JIT
    JIT
    Mar 2, 2002
    1,188
    38
    Glasgow
    +8
    Yes, that worked but I have no idea what to do next so I just turned off the set and then back on again to get it back to normal.
  4. fjollon
    fjollon
    What did you want to do in the meny?
  5. JIT
    JIT
    Mar 2, 2002
    1,188
    38
    Glasgow
    +8
    Jut check the settings, that's all as i'm quite happy with the set like it is. As i'm not sure what all the numbers/letters mean i did not change anything.
  6. Guest
    Just to dig this thread up slightly, does anyone have a list of what does what within the service menu's on the tosh???
    (more importantly i wanna see if there is any way of disabling SVM via the menu rather than ripping the set apart!!)
    Paul
