Service Menu on Panny TH37PE30B
Discussion in 'Plasma TVs' started by VieraUser, Sep 13, 2004.
  1. VieraUser
    VieraUser
    Can anyone tell me how to access the Service Menu on on my Viera TH37PE30B. Many thanks
  2. pjclark1
    pjclark1
    Jul 19, 2004
    4,411
    Thailand
    +271
    Try This (at your own risk)
    Activate Service Mode: With the unit turned on. Press & hold the VOLUME DOWN /- button on the chassis front panel and at the same time quickly press the Remote Control STATUS button [+] 3 times.
    Select Adjustment Item: Press the LEFT and RIGHT buttons on the remote control.
    Select Category: Press the ACCESS button on the remote control. Press the UP and DOWN buttons on the remote control to select the alignment subject.
    Change Data: Press the VOLUME UP /+ and VOLUME DOWM /- buttons on the remote control.
    Exit Service Mode: Press "R" on the remote control to exit the IIC mode. To exit the CAT (main service mode) use the DOWN button on the remote to select the ID mode, and then switch the main power off and back on.
  3. VieraUser
    VieraUser
    Many thanks. I have a calibration CD, are there items in the service menu that should be adjusted when using the calibration CD.
