Service Menu on Older Panasonics ????
Discussion in 'General TV Discussions Forum' started by jerkyboy, Dec 9, 2003.
Tags:
  1. jerkyboy
    jerkyboy
    I have just obtained a 29" Panasonic 4:3 TV from my mother to use as a games telly.
    The picture is very good but could do with some tweaking. (I cant change the colour when using RGB for example)
    Is there another way to access the service menu on Panasonics other than the usual Bass max, treble Min system.
    The TV is about 7 years old now, so I dont know if service menus even existed then.
    Any sugestion would be appreciated.
  2. CARLOS
    CARLOS
    Feb 11, 2001
    6,455
    WEST MIDLANDS
    +1,412
    Whats the model number ?
  3. gbmitie
    gbmitie
    Apr 25, 2001
    1,141
    49
    republic of ireland now
    +62
    I think I have the same set and I can't change colours in RGB either. If it is possible with service menu I would be interested.
    I have accessed the service menu to adjust that dreaded shift when usIng RGB. I will try and idg out the seqquence to get ar service menu/
    The model of mine is someting like tx29ad1.
    gbmitey
