service menu loewe xelos lcd
Discussion in 'LCD & LED LCD TVs Forum' started by skinboots, Sep 21, 2005.
Tags:
  1. skinboots
    skinboots
    Oct 2, 2004
    76
    Berlin
    I'm trying to solve certain geometry- and dnr-issues on my loewe xelos a 37. could someone please help me to get in to the service menu? I promise to be careful !
    kind regards
    thomas
  2. andrewfee
    andrewfee
    Apr 27, 2004
    3,066
    +500
    Geometry issues on an LCD? Sounds like a hardware fault... :eek:
  3. skinboots
    skinboots
    Oct 2, 2004
    76
    Berlin
    geometry-issues as in "underscan" - very slight at either side of the picture and still better than "overscan"; and the dnr is set to high over scart and to low on the other inputs - dnr can only be set in the service menu, and ideally I'd like to switch it off.
    anyone?
    thomas
  4. s3marc
    s3marc
    May 10, 2005
    134
    +5
    on the TV press the 'menu' button , using the remote control move the cursor until you get to the 'service menu' option (this will not appear if you press menu on the remote - it must be from the tv) and press select - sometimes it takes a few attempts to get into it.
    As you say, take care in there - you can render your TV unworkable and will need a Loewe engineer to come and reset it.
    if you plan on changing any settings, write them down first
    Marc
