Service Menu JVC AV28WFT
Discussion in 'General TV Discussions Forum' started by PETERDELVE, Nov 19, 2001.
  1. PETERDELVE
    PETERDELVE
    Is there any way the reset the settings in the service menu. Or perform a factory reset on the setting in the service menu?
    I want the change some setting in the DEF section (RGB shift) but want the make sure that I cannot undo any changes.
    Or does any have a list of the correct settings for the items under the service menu 'DEF' for reach zoom mode.
